Latest: tbafonso
Overall: 17130
Online Now [75]:
Visitors: 74
Today: 4213
Total: 102476504
Forums › The Car › 206 Problems › 206 04 reg speedo
206 04 reg speedo
ali40
PostPosted: Wed Jul 06, 2011 1:01 pm Up
hi all bought a 206 04 reg speedo and millage dont move but checked car out there's no speedo sensor on gear box blanked of so why is my speedo not working also changed clock no luck there please help .also done the road test drove car open door light flashes beeps .
peugeot 206 1.1 s
PostPosted: Wed Jul 06, 2011 1:13 pm Up
No speed sensor? Confused you sure?
Open the door and start driving and see if the interior light flashes and/or you get a beeping noise
ali40
PostPosted: Wed Jul 06, 2011 1:16 pm Up
done road test beeps and flashes
peugeot 206 1.1 s
PostPosted: Wed Jul 06, 2011 1:24 pm Up
Then it has a speed sensor. Faulty cluster
ali40
PostPosted: Wed Jul 06, 2011 1:27 pm Up
it dont have a speed sensor its got a plug on it no wire nothing i looked in haynes manual it says som cars have sensor some have a plug later models
peugeot 206 1.1 s
PostPosted: Wed Jul 06, 2011 1:36 pm Up
If the car is recognising you car is moving then it has a speed sensor. Some use the ABS ring
ali40
PostPosted: Wed Jul 06, 2011 1:42 pm Up
yesno sensor on gear box could be with abs sensor so what should i try to change abs speed sensor took it for a scan guy said no signal coming to dash
peugeot 206 1.1 s
Is the odometer still working?
ali40
PostPosted: Wed Jul 06, 2011 1:43 pm Up
no speedo and no millage moving all else is good
peugeot 206 1.1 s
PostPosted: Wed Jul 06, 2011 1:45 pm Up
If he plugged the diagnostic stuff in, then he should have been able to read live data. If there is live data then its the cluster. If not, then its a sensor
ali40
PostPosted: Wed Jul 06, 2011 1:47 pm Up
is a cluster part of the clock what s a cluster exactly
peugeot 206 1.1 s
PostPosted: Wed Jul 06, 2011 1:49 pm Up
The speedo, rev counter, mileage, fuel guage, oil gauge etc
ali40
i have tried a complete clock of another working car but same problem
peugeot 206 1.1 s
ali40
PostPosted: Wed Jul 06, 2011 1:50 pm Up
so which abs sensor controls the speedo so i can change it thanks
peugeot 206 1.1 s
ali40
PostPosted: Wed Jul 06, 2011 2:00 pm Up
im thinking the same a wheel speed sensor but which one there's no abs light on 2 air bag lights are on but car was in a crash and repaired before i bought it its a nice 1.1 exept speedo dont move or millage
peugeot 206 1.1 s
