Online Now [571]:
Visitors: 570
Today: 10089
Total: 105904130
Forums › The Car › 206 Problems › Leaking rain!
Leaking rain!
joshack
PostPosted: Thu Jul 07, 2011 5:49 pm Up
I get a lot of rain water under my rear seats, no idea where it comes from as i have checked all the door seals and window seals and the boot seals.
Has anyone had this problem and how can i solve it, any help would be good.
Thanks Josh
Car is a 1.9d 5 door
drive:206 lx diesel
Rob2859
PostPosted: Thu Jul 07, 2011 5:55 pm Up
check the rubber around the rear window again? Is the boot carpet wet too?
joshack
PostPosted: Thu Jul 07, 2011 6:11 pm Up
Nope boot carpet doesnt get wet, just under the seats. Not coming from under the car either as It happens over night.
drive:206 lx diesel
Rob2859
PostPosted: Sat Jul 09, 2011 5:27 pm Up
sit in the car while someone hoses it down to try and find the leak
DREWDEN
PostPosted: Sat Jul 09, 2011 6:00 pm Up
I had a problem like yours, not as bad though. 5 door same.
I seem to remember unclipping the rubber seals which are joined together at the bottom of the doors, and pulling up more or less nearly taking them off.
then starting from the top, when you get to top corners make sure you push them up tight, you'll know what imean when you do it.
That solved my problem.
206 2ltr Hdi glx 53 plate
