Latest: tbafonso
Overall: 17130
Online Now [315]:
Visitors: 314
Today: 47768
Total: 104579534
Forums › The Car › 206 Problems › two problems to start off with, help needed.
p206gti
PostPosted: Sat Jul 09, 2011 1:04 pm Up
Hello there everybody, newbie here with a couple of questions but im sure there will be more to come!!
First off we just got our 206 gti (v reg) home to find the display at the top of the dash isnt working, there's no time date etc nothing just blank, is it easy to take out and what is the likely hood its something simple or do they just die?
Secondly thisone might be more expensive i fear, the front car looks like its been lowered but the back is sticking up in the air and just looks very high to me, ive been looking at threads and maybe its the rear beam thats faulty or is it a case of the torsion bars are knackered and need replaceing, i know there's no spare wheel in the back so there's no wieght but i cant believe it should be that high.
steve
Abzynthe
PostPosted: Sat Jul 09, 2011 1:08 pm Up
East Area Rep - Abzynthe
threres a how to on here for a fix on the display if thats whats wrong with it, and if the front looks like its been lowered, maybe the torsion bar is standard height?
Got any pics of it?
p206gti
PostPosted: Sat Jul 09, 2011 1:28 pm Up
i'll take some piccy tommorow but the back end as about 3-4 inches between the wheel and rear wheel arch, just doesnt look right if that makes sense.
Abzynthe
PostPosted: Sat Jul 09, 2011 2:10 pm Up
sounds about right tbh.
PostPosted: Sat Jul 09, 2011 2:37 pm Up
Is it the bulbs that have blown on the display?
DeadEyePaul
PostPosted: Sat Jul 09, 2011 2:45 pm Up
The standard height of the front on all 206s look as if the nose of the car points down (Peugeot did this on purpose) I'll see if I can get a picture of my car when it was a stock car
p206gti
PostPosted: Sat Jul 09, 2011 2:46 pm Up
thanks for the info people very much appreciated, ive just done a search to see how you go about fixing the info display but cant seem to find anything but i'll keep searching, i'll deffo get some pictures up tommrow as ive just polished it tonight so its looking a bit better now!
DeadEyePaul
PostPosted: Sat Jul 09, 2011 2:51 pm Up
Now lowered
And for a laugh..
Abzynthe
PostPosted: Sat Jul 09, 2011 2:54 pm Up
Rolling On The Floor Laughing
DeadEyePaul
206info.co.uk/Forums/v...ppt30.html
How to fix clock - found it
p206gti
PostPosted: Sat Jul 09, 2011 3:13 pm Up
THANK YOU VERY MUCH for the photos and links, just loooking at y9ours doesnt make me feel too bad about ours now, i'll take some pictures tommorow and let everybody see what they think
DeadEyePaul
PostPosted: Sat Jul 09, 2011 3:21 pm Up
Good luck with the clock, if your unsure about soldering check out YouTube the tutorials on there which are very good (missed too much of school to learn this skill) you apply the iron to the broken component on the board to heat it (2-3 secs) then touch the part with the solder the solder should flow onto the broken part
p206gti
PostPosted: Sun Jul 10, 2011 12:03 pm Up
heres a couple of piccys that i took today hope it helps out!,
leigh_boy
PostPosted: Mon Jul 11, 2011 2:23 am Up
if you cant fix it i have a com,plete unit from a 99 gti that does work for £15 + postage Smile
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
