Latest: tbafonso
Overall: 17130
Online Now [310]:
Visitors: 309
Today: 15809
Total: 104597593
Forums › The Car › 206 Problems › Engine Management Light Issue
m.killeavy
PostPosted: Sat Jul 09, 2011 2:24 pm Up
Hi all, New to this but wonder if anyone can help?
My Car died a few days ago, after engine management light came on. I started up again fine and worked as normal too. Light went off after a day but same thing happens today, it seems to only happen after five mins of starting? Any ideas, I also have a problem with header tank not holding coolant properly wondered if that might be associated?
It's a 206 1.6 2001 Y. Smile
Ali_H
PostPosted: Sat Jul 09, 2011 2:30 pm Up
Get the codes read mate.
kurtis wrote:
m.killeavy
PostPosted: Sat Jul 09, 2011 2:34 pm Up
Cheers pal is that something any garage can do or can you get a bit of kit to do it your self?
206 1.6 Roland Garros
PostPosted: Sat Jul 09, 2011 2:36 pm Up
Just take it to an auto electrician and chuck them a few quid for telling you what it says.
Norvvv
PostPosted: Sat Jul 09, 2011 7:28 pm Up
Headgasket probably Sad
2001 1.4lx
PrePlexed 5 door.
MrrNoName
PostPosted: Sun Jul 10, 2011 12:27 am Up
under what assumption lol??
the header tank loosing water could simply be a bad fitting onto its hose. the car "dieing" could be anything, fuel, electrical, etc.
everyone always jumps to the HG DOH!!!
PostPosted: Sun Jul 10, 2011 3:53 am Up
Where abouts are you from?
Ali_H
PostPosted: Sun Jul 10, 2011 4:24 am Up
Main dealers or local garages with the right reader, or there's some people on here that do it like Lee ^^
kurtis wrote:
