Posted: Sat Jul 09, 2011 4:22 pm |
Hi been here a while and never posted but problem on the other halfs car the MFD has gone blank i know its the bulb as u can still see partially during the day and nowr at night. Read thw guide on here to change them seems fairly simple but read elsewhere you need to disconect the battery only trouble is we dont know the radio code and peugot charge for the code. What I want to know is, is it possible to safely chage the bulbs without disconecting the battery.
Cheers
| Back and posting after along time away | |
Posted: Sat Jul 09, 2011 4:27 pm |
206info.co.uk/Forums/v...ppt30.html
This link will assist you with removal of the clock then you can remove the required bulbs
In reguards to your radio that is coded to your car so you wont loose your radio
Posted: Sat Jul 09, 2011 4:40 pm |
cool thanks wasnt sure as the battery died few months so was replaced but radio was fine but read somewhere else online that battery needed disconecting and in this instance the radio will need reprogrammed. Guess that place was wrong lol cheers for the help
Posted: Sat Jul 09, 2011 4:44 pm |
Posted: Sat Jul 09, 2011 4:46 pm |
| DeadEyePaul wrote: |
http://206info.co.uk/Forums/viewtopic/t=206/highlight=ppt30.html
In reguards to your radio that is coded to your car so you wont loose your radio |
Surely that depends if its plexed or not
Posted: Sat Jul 09, 2011 4:48 pm |
Well then he can replace the standard one for a better one for half the cost of the code!
Posted: Sat Jul 09, 2011 4:53 pm |
Well then he can replace the standard one for a better one for half the cost of the code!  |
Posted: Sat Jul 09, 2011 4:58 pm |
lee sells the codes for a quid on here, doubt you can get a hu for £2 lol
Posted: Sat Jul 09, 2011 6:42 pm |
