Latest: tbafonso
Overall: 17130
Online Now [51]:
Visitors: 50
Today: 42908
Total: 104574675
Forums › The Car › 206 Problems › Won't go into 4th or reverse
austin316
PostPosted: Mon Jul 11, 2011 4:36 am Up
Hi guys. I was driving yesterday. All going well then i came to a roundabout. Pulled off normally and went to go into 2nd gear and it grinder like I didn't have the clutch down. Turned car off then on again and 2nd gear now works, but the gear stick now won't go into 4th and reverse? Not too sure what problem is tho. Any ideas? Thanks
5 door
1.1 8v
04 reg
PostPosted: Mon Jul 11, 2011 4:37 am Up
Check your gear-linkages. Do you have a quickshift fitted?
JE_180
PostPosted: Mon Jul 11, 2011 4:39 am Up
That's what happened to mine when my gear linkage cable broke... apart from I couldn't select any gear.
austin316
PostPosted: Mon Jul 11, 2011 4:41 am Up
No quickshift fitted and I'm not all that good with cars. Where am I looking for gear linkages, and what am I looking for? Thanks
5 door
1.1 8v
04 reg
PostPosted: Mon Jul 11, 2011 4:46 am Up
206info.co.uk/Forums/v...=1788.html
See this topic. You may be able to check from under the car too.
panzer360gti
If you dont know much about cars, get to know your local mechanic at the garage!
Peugeot 206 GTI 137 2.0
Andrew
PostPosted: Mon Jul 11, 2011 5:06 am Up
If it turns out they need replacing, as CD-530d about some stainless ones, they are supoib!
My 206 thread
www.detailedbyandrew.com
Dabamash
PostPosted: Mon Jul 11, 2011 5:30 am Up
Staff - Daba
If you take it to a garage, you'll never learn stuff about cars.
matt.handley
PostPosted: Mon Jul 11, 2011 5:40 am Up
thats exactly what i think, would much prefer to learn myself
leigh_boy
PostPosted: Mon Jul 11, 2011 5:43 am Up
something is obstructing the gear linkages seen it before Smile
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Mon Jul 11, 2011 5:45 am Up
then get a haynes manual
Rob2859
PostPosted: Mon Jul 11, 2011 6:31 am Up
I have one but I think they are crap imo. My Dad thinks that too, he says there is not enough detail, however he is like James May. I prefer to muddle though Very Happy
brimbo
PostPosted: Mon Jul 11, 2011 8:23 am Up
Might be gear linkages, same happened to me, I could only go in 3rd,5th and reverse Sad a stall to many !
W-reg 1.4 LX
