Online Now [57]:
Visitors: 56
Today: 17541
Total: 104945185
Forums › The Car › Request a how-to › gear box oil level
gear box oil level
Forum IndexRequest a how-to
ali_craig
PostPosted: Mon Jul 11, 2011 1:03 pm Reply with quote Up
hey
a have a 1.1 206 51 plate and would like to now how to check gear box oil level and also how much the gear box holds as a may drain/fill with new oil,
cheers
ali
please help!
Rob2859
PostPosted: Mon Jul 11, 2011 1:13 pm Reply with quote Up
It holds 2 litres. If its not been changed in a while then do it. You can not overfill them. If you remove the battery and tray you will see a black plastic cap on top of the gearbox where you can put the oil in.
If you want to empty the oil fast and make a big mess pull the drive-shaft out Whistle... However there is a better way of doing it.
PostPosted: Mon Jul 11, 2011 1:42 pm Reply with quote Up
who said you cannot overfill the gearbox with oil? Laughing
eddrj
PostPosted: Mon Jul 11, 2011 1:44 pm Reply with quote Up
you can overfill them just pours straight back out
Old car 2000/ 206 2.0 hdi.
PostPosted: Mon Jul 11, 2011 1:47 pm Reply with quote Up
not when you pour the oil in through the breather hole. Laughing
Rob2859
PostPosted: Mon Jul 11, 2011 1:56 pm Reply with quote Up
I mean you can not damage them from putting too much in.
PostPosted: Mon Jul 11, 2011 2:05 pm Reply with quote Up
depends on how much you mean too much.
but in general it will put more pressure onto the oil seal,
more oil=lower gear oil temp= stiffer gearchange
  Quick Reply
Username:
Message:
Quote the last message
