Latest: tbafonso
Overall: 17130
Online Now [451]:
Visitors: 450
Today: 18206
Total: 103880375
Forums › The Car › 206 Talk › Refurb tips
Refurb tips
warren
PostPosted: Thu Jul 14, 2011 3:28 am Up
I'am Just wondering if anyone has any step by step guides on how best to refurb some alloys wheels. I'am looking to get some cheap 16" nimrods and refurb them but i dont know if it will be easier to just take them to get them done or do them my self.
Thanks.
JE_180
PostPosted: Thu Jul 14, 2011 3:33 am Up
Search is wonderful.
206info.co.uk/Forums/v...art=0.html
warren
PostPosted: Thu Jul 14, 2011 3:35 am Up
Is when you know how to use it :\
Thanks alot mate
craigdmjv
PostPosted: Thu Jul 14, 2011 3:38 am Up
i would personaly get them done correctly by a pro
Mrs_Howey
PostPosted: Thu Jul 14, 2011 3:52 am Up
I would agree there too, by the time you have spent out all the money on getting filler and paint you might as well have paid to have it done.
I've done it and i will never ever do it again, was total not worth it! Smile
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
JE_180
PostPosted: Thu Jul 14, 2011 3:58 am Up
Depends how good you are at it... and filler/paint isn't going to cost the best part of £250 like a pro refurb generally costs.
Lewis
PostPosted: Thu Jul 14, 2011 4:07 am Up
unless you live near city powdercoaters (lucky buggers) then surely its a good option to do it yourself if your compitent!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
warren
PostPosted: Thu Jul 14, 2011 4:09 am Up
Think i might have ago my self, i work in a motorcycle garage so i got some where to do them and can leave them there as well to dry.
If get them done for by a pro knowing my luck (and parking skills) i will end kurbing them in the first week and feel bad about spending £200 getting them done.
Is there any type of paint and primer that any one recommends that is better than the rest?
JE_180
PostPosted: Thu Jul 14, 2011 4:16 am Up
You'll probably want to use Etch primer as it's bare metal, but just put plenty of layers of paint and lacquer on Smile
kieron
PostPosted: Thu Jul 14, 2011 4:35 am Up
or unless you can get halfords paint £1 a tin
Account suspended
SmithyXSI
PostPosted: Thu Jul 14, 2011 5:00 am Up
If you can help it and they're still factory painted you're best just sanding the paint off and leaving the white primer underneath as far as you can then primering again over the top.
I've done 2 home refurbs with Halfrauds filler primer, primer, paint and lacquer and they've all come out pretty well.
My tip would be practice lacquering beforehand. A run from too much is so irritating because you have to pretty much start again but not enough and you get an 'orange peel effect' in my experience.
Best of luck!
2003 206 2.0HDi. I miss my 106 GTi.
PostPosted: Thu Jul 14, 2011 5:42 am Up
many local place do sand blasting and powder coating very cheap.
few place in leeds cost about 15 quid per wheel.
JE_180
PostPosted: Thu Jul 14, 2011 6:42 am Up
£15 per corner? Isn't it usually more like £40
Ali_H
PostPosted: Thu Jul 14, 2011 7:34 am Up
You caqn normally find a refurb for around £120-150 max if you look hard enough.
Several places down here will do the lot for £100-120.
kurtis wrote:
PostPosted: Thu Jul 14, 2011 12:29 pm Up
You'd use filler and paint on wheels? A pro will shot blast, weld, machine and powder coat the front and backs of wheels. You can't do that DIY.
