Posted: Tue Jul 12, 2011 6:25 am |
The battery blew my central locking and windows. How should I go about fixing them?
The hazards flash as they should but nothing happens and using the key only operates the door that the key is in.
Posted: Tue Jul 12, 2011 8:58 am |
tried fuses?
*Corrected* lol
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Tue Jul 12, 2011 9:52 am |
Or the fuses (Sorry MrrNoName, I'm bored )
Posted: Tue Jul 12, 2011 10:25 am |
Yes sorry I checked those first
Posted: Sat Jul 16, 2011 1:39 am |
You need a diagnostics check first otherwise you are throwing money away. I have just had the same problem but only with my doors not operating and unfortunately had to replace all of my door latch motors. Diagnostics will cost around £30 but dont use a
PUG dealer they will charge nearer £60. Lets hope its something simple.
Posted: Sat Jul 16, 2011 2:38 am |
Rob2859 wrote: |
The battery blew my central locking and windows. |
How did the battery do this? I've heard of things stopping working due to bad earths and the like, but never just from being connected to a battery, which is what they are designed for in the first place.
Don't just check the fuses by eye, use a multimetercontinuity tester to make sure that they are still useable.
Posted: Sat Jul 16, 2011 2:41 am |
macca1411 wrote: |
Don't just check the fuses by eye, use a multimetercontinuity tester to make sure that they are still useable. |
the man speaks sense, sometimes you cant just tell by eye
