Latest: Beduff1977
Overall: 17134
Online Now [638]:
Visitors: 637
Today: 71436
Total: 107731667
Forums › The Car › 206 Problems › Testing fan
Testing fan
gmcminn
PostPosted: Mon Jul 18, 2011 1:43 am Up
Hi folks, my 2003 1.4 temperature rises up to about 100 degrees and engine management light comes on & engine misfires. Fan seems to kick in but doesn't seem to cool engine down as quick as normal.
Is the 2 speeds for fan???
Have replaced both temperature sensors & no change. Please help. Cheers
PostPosted: Mon Jul 18, 2011 5:43 am Up
Have you checked the relays and the wiring to them? They regularly suffer from corrosion on even the most cared for cars.
gmcminn
PostPosted: Mon Jul 18, 2011 2:46 pm Up
Haven't checked yet mate. Wil do 2moro. Not sure though if 1 or 2 speeds???
pug 206
scousemouse
PostPosted: Tue Jul 19, 2011 12:03 am Up
if car has air con fan will be 2 speed
if you can\'t fix it with a hammer your problem\'s electrical
