Online Now [1262]:
Visitors: 1261
Today: 18363
Total: 146721456
Forums › The Car › 206 Talk › key barrel replacement
Forum Index › 206 Talk
Billionaires-123
PostPosted: Fri Jul 22, 2011 9:26 am Up
Hi peeps
my lil sister had an attempted car theft.
they have completley ruined the key barrel on the drivers side.
I was just wondering can you replace the key barrel without messing up the central locking etc? and is it fairly easier?
i am aware the old key wont work but will be far more pleasing aesthetically
thanks
206 gti 138 moonstone blue
PostPosted: Fri Jul 22, 2011 10:08 am Up
You could go to dealer and order a barrel to the key number.
As far as I know, there should only be a link rod from the barrel to the solenoid. Most of the time they are only held in with a horseshoe clip on the inside of the door skin.
PostPosted: Fri Jul 22, 2011 2:18 pm Up
I have a full lock set for sale including two keys if you want them Wink
meady
PostPosted: Fri Jul 22, 2011 2:19 pm Up
Trade Rating: +45
if you get a barrel made to your key mate it will be alot better as you can still use ikt. Also changing a barrel is a 5 min job. Just take off the door card, slide the horseshoe clip off and unhook the link rod from it. Then do the reverse to fit the new one
TEAM - I HATE FACEBOOK Smile
Billionaires-123
PostPosted: Tue Jul 26, 2011 5:27 am Up
thanks for all the replys and apologies in delay
Lee - how much?
and how much am i looking at for 1 barrel to match the exsisting key?
thanks
