Latest: tbafonso
Overall: 17130
Online Now [284]:
Visitors: 283
Today: 46037
Total: 103908168
Forums › The Car › 206 Problems › List of problems with my 206 :(
kakaruto
PostPosted: Wed Jul 20, 2011 12:08 pm Up
hello all i was wondering if any of you guys out there can help me diagnose the problem i have with my 206 and find a soloution to fixing it?
i bought my 206 Monday night and got it back home, when i went up to bolton to purchase the 206 i test drove it and it started fine and drove fine.
got it home around 10:45pm kicked her up while it was on flat bed to get her off and it started then cut out, started her up again and she kicked up and stayed on, then i noticed the alternator was squeeling. we reversed it off flat bed, parked it up on side street, then when i tried to kick her up again after being stood 10mins the battery was flat so i had to use my bros yaris to jump start her... took it for a spin around the block, then parked it up in my on my back yard, while manouvering the car around on my back yard i noticed smell of coolant, checked my temp gauge and it was in the red zone!
no sign of fan kicking in at all! thought it might of been the blue temp switch but when i took coolant cap off the coolant was scolding hot!.
kicked her up tuesday to show a mate of mine and she cuts out if you dont give it a bit of rev...
what could be the problem?
2001 Y 206 1.4 LX Black
Ste
PostPosted: Wed Jul 20, 2011 12:12 pm Up
Staff - Ste
Coolent, check the fuses, relays and thermo's
Cutting out, check your ICV isnt gunked up / clean it
The Cars:
PostPosted: Wed Jul 20, 2011 12:15 pm Up
The starting cutting out and not staying on untill you rev it a bit I had with mine as we were getting towards last winter turned out to be my battery on its lasts legs not holding its charge properly.
kakaruto
PostPosted: Fri Aug 05, 2011 3:37 pm Up
well managed to get my car up to my work and get it looked it, we plugged in a diagnostic machine and it threw up a fault code P0485 cooling fan interupted ECU operation.
so we checked the wiring and relay and guess what! the wiring was corroded to fk! as well as the relays.
so mechanic had to go to scrappy to fetch a wiring loom and re do wiring :/ it works now and the cutting out was a duff battery lol
thanks again to all those who have helped
