Latest: tbafonso
Overall: 17130
Online Now [50]:
Visitors: 49
Today: 16923
Total: 103808470
Forums › The Car › 206 Problems › Springs Or wishbone
Springs Or wishbone
mrsc
PostPosted: Thu Jul 21, 2011 2:26 pm Up
hi there i hit a kirb Sad and now have a prroblem my wheel is touchin the wheel arch near the door and scrapping along it as i drive when i break it makes a funny noise and also when i go over bumps sounds like it scrapes looked at the top of the spring in bonet looks bent and also the drivers side witch is ok is in line with 2 caps to hold the mudguards in place but other side the last spring is alot lower
thanks in advvamce
si
PostPosted: Thu Jul 21, 2011 2:29 pm Up
1. Use punctuation, it makes it easier.
2. Which wheel? I'm presuminf front passenger as rear doesnt have springs.
PostPosted: Thu Jul 21, 2011 2:30 pm Up
looks like you bent the strut, but without actually looking no one can tell
mrsc
PostPosted: Thu Jul 21, 2011 2:34 pm Up
sorry Front passenger
basically its touching the wheel arch near the door when i drive you can here it scrapping and when i break it souns louder
si
PostPosted: Thu Jul 21, 2011 2:37 pm Up
Wishbone will definately be bent. It's that which controls the position of the wheel.
brimbo
PostPosted: Thu Jul 21, 2011 3:18 pm Up
Get a photo, it'll explain it better
W-reg 1.4 LX
