Latest: tbafonso
Overall: 17130
Online Now [229]:
Visitors: 228
Today: 506
Total: 102472808
Forums › The Car › 206 Problems › Injectors on 206 GTI 2000
panzer360gti
PostPosted: Tue Jul 26, 2011 4:28 am Up
Can anyone post some pics of injectors/injector removal, I want to have a look at them and possibly clean/change them, but cant find anything in the how to's?
Peugeot 206 GTI 137 2.0
PostPosted: Tue Jul 26, 2011 4:58 am Up
Un bolt fuel rail and pull out.
PostPosted: Tue Jul 26, 2011 5:13 am Up
Aren't there also small metal clips on the rail too?
PostPosted: Tue Jul 26, 2011 5:14 am Up
There may well be. It's been a few months since I last looked at a GTi engine.
panzer360gti
PostPosted: Tue Jul 26, 2011 5:53 am Up
I did undo two bolts on the rail a bit ago one at each end, but the rail felt like it was still bolted in, could this just be age?
I'll have a look anyway.
panzer360gti
PostPosted: Thu Jul 28, 2011 3:23 am Up
Got nowhere with taking the rail out here, do you have to release the air pressure from the schrader valve on top?
Also, is it worth taking them out to clean? Can they actually be cleaned to improve performance?
I'm looking at getting new, Im sure one or two arent working.
Visually they look old, rusty and as if theyve never been touched in ten years.
DREWDEN
PostPosted: Thu Jul 28, 2011 2:26 pm Up
Injectors are a very high precision bit of kit, they are not meant to be removed for cleaning. Only for renrwal.
diagnostics will tell you how good they are.
just had mine checked and told they were in good nick.
206 2ltr Hdi glx 53 plate
