Online Now [98]:
Visitors: 97
Today: 77421
Total: 117031359
Forums › The Car › 206 Talk › A/C Drain Hose
A/C Drain Hose
PostPosted: Sun Jul 24, 2011 5:41 am Up
Hi All,
As most of you know that when you turn A/C in the hot weather,there will condensation because of the temp diff. between outside and inside the Evaporator,which is located inside the heating/cooling unit.
So my car was doing this last year,but this year,I recharged it,and it's very cold,but there is no water pond under neath the car,so I was wondering if there someone faced this situation before,can the A/C drain hose be cleaned?and where it's located in the 206??
Tim
dumdum0910
PostPosted: Sun Jul 24, 2011 10:54 am Up
i want to no this aswell as mine doesnt seem to drain anything
PostPosted: Mon Jul 25, 2011 12:19 pm Up
Well my friend,it seems no one know anything about this I'm afraid Sad
Andy180+
PostPosted: Mon Jul 25, 2011 2:06 pm Up
i think it is a bout the heat sheild above the cat . if i remember right mine drips from that area
PostPosted: Wed Jul 27, 2011 7:04 am Up
Thank you so much for your reply,I will give it a check right now Smile
