Posted: Fri Jul 29, 2011 10:25 am |
Trade Rating: +46
well my partner and me have been tinkering on with my gti 180 today, just found out all harness mounting points are difrent to my old gti138, i meen diffrent as in bolt size.. harness eye bolts will not fit they are to big , anyone else found this out.......
Posted: Fri Jul 29, 2011 10:27 am |
100% sure they are the same size.
7/16" UNF
Posted: Fri Jul 29, 2011 11:45 am |
Trade Rating: +46
well so were we but they are not... tryed and tryed again difrent thread and to small example its like trying to put a 9mm bolt on a 10mm nut
Trade Rating: +46
must be a factory f**ck up
Posted: Fri Jul 29, 2011 11:52 am |
shell-vt wrote: |
well so were we but they are not... tryed and tryed again difrent thread and to small example its like trying to put a 9mm bolt on a 10mm nut |
measure the orginal seatbelt bolt to see what they are?
sounds odd though.......
which mounting point you mean btw?
pretty sure front seat top belt(B-pillar) and lower belt (B-pillar) are 7/16" UNF
although i am not sure about the bolt size for the seat belt buckle.
Posted: Fri Jul 29, 2011 12:19 pm |
Trade Rating: +46
b-pillar,s both sides i will get a pic up tomorrow first time ive ever seen this myself, as to why i thort it was odd...
Posted: Fri Jul 29, 2011 12:39 pm |
Thought that you bought the wrong thing?
| 206 1400 8v HDi, Battle Bus - More Radical than Peugeot
In theory, there is no difference between theory and practice. In practice, there is. | |
Posted: Fri Jul 29, 2011 1:12 pm |
Trade Rating: +46
no all harness bolts are the same buddy long and short...
Posted: Fri Jul 29, 2011 1:16 pm |
don't need a pics to be honest....
just get the measurement of the OEM bolts will do....
Posted: Fri Jul 29, 2011 1:51 pm |
Trade Rating: +46
says 8.8 on oem bolt
Posted: Fri Jul 29, 2011 1:57 pm |
that is the grade of the bolt, not dimension..?
Posted: Fri Jul 29, 2011 3:25 pm |
Trade Rating: +46
my odd ball bolt not the best pic but hope you can see
Posted: Fri Jul 29, 2011 5:34 pm |
although the bolts shape look like the right one, but without any measurement it is hard to tell.
but for some reason all seat belt bolts i have got are black (OEM bolts)
Posted: Sat Jul 30, 2011 8:21 am |
Well either your harness bolts are the wrong ones, or you putting them in to the wrong places.
You CAN buy eye bolts that are not 7/16 UNF.
Posted: Sat Jul 30, 2011 8:38 am |
OEM seat belt screws are
7/16"20 LONG 47 - bolt that holds belt that goes on your lap
7/16"X20-8 - shoulder bolt
7/16X20 LONG 10,5 - buckle
7/16"X20 LONG 35 - rear under seats
7/16"X20 LONG 35 - rear seats holding belt across lap and shoulder
