Posted: Sun Jul 31, 2011 6:47 am |
On the transmission of a BE4 gearbox from a GTi, anyone know the layout and function of the three wires. I am trying to make a digital processor for stage distance and time to work from one.
Posted: Sun Jul 31, 2011 7:05 am |
The MM 4.8P or the MM 4MP2 ecu?
Posted: Sun Jul 31, 2011 7:12 am |
Its all on stand alone ECU. I have a bare canvass mate. The rally trip computor needs a pulse signal. It can input 5volts to the sensor and has a wire from the pulse terminal and a -ve wire. The problem is I can either use an old ABS sensor on one wheel to feed it a pulse or use the gearbox sensor. I just dont want to fry anything
Posted: Sun Jul 31, 2011 7:23 am |
Pin 1 - CM32M - voltage - engine fuse box
Pin 3 - 6739 - vehicle speed info
Pin 2 - MM01A - earth
Posted: Sun Jul 31, 2011 7:26 am |
nice one mate.... now how do I know which is pin1
I assume pin 3 is middle
Posted: Sun Jul 31, 2011 7:35 am |
If you look very closely there will be numbers
nah pin 3 is at the end, i just listed them in the order that I read them off the diagram
normally Pin 1 is to the right
Posted: Sun Jul 31, 2011 7:40 am |
looks like I need to borrow some glasses then.... cheers for the help bud. Hope the hangover is better
Posted: Sun Jul 31, 2011 7:42 am |
I'll have a look to see if I have one in the shed to see if I can see them.
Dunno if I left it on the engine when I sold it or not
Posted: Sun Jul 31, 2011 7:46 am |
I spent about an hour trying to find a 3 pin plug for it.... I junked the whole loom when I built the car so will be off to the scrappy tomorrow
Posted: Sun Jul 31, 2011 7:47 am |
Does it look like this?
Posted: Sun Jul 31, 2011 7:53 am |
nope.... thats the cable drive unit I think, looks like this
Posted: Sun Jul 31, 2011 8:04 am |
And now I can see the numbers
Posted: Sun Jul 31, 2011 8:14 am |
and a slightly cleaner version.
Posted: Sun Jul 31, 2011 8:19 am |
macj wrote: |
And now I can see the numbers  |
Posted: Sun Jul 31, 2011 9:56 am |
Yes Ed..... its a bit grubby round there
