Online Now [36]:
Visitors: 34
Bots: 2
Today: 33719
Total: 116769907
Forums › The Car › 206 Problems › Fault code reset limit?
rich1162
PostPosted: Sun Jul 31, 2011 2:52 pm Up
My fantastic piece of French engineering is suffering from the constant engine warning light that comes when you have a non-Peugeot catalytic converter installed. The fault code I get is "ageing cat" but it's less than a year old, has been checked for faults by the company that fitted it and my regular garage and has just passed the MOT with no emissions problems.
From reading posts on here it sounds like a common problem, I get the light reset, it stays off for a about a week or so, then comes back on with the same fault. Since I don't fancy shelling out for a new Peugeot cat, I was going to get a fault code reader and reset the warning light myself every time it comes on, but then I read a post that says you can only reset the warning light 50 times before you have to replace the ECU. Does anyone know if this is true?
Thanks,
Rich
Rich :: 2001 1.4 GLX
NICKST
PostPosted: Mon Aug 01, 2011 1:13 am Up
I don't think that is true. Best speek to lee he will now for sure.
PostPosted: Mon Aug 01, 2011 1:19 am Up
I've read the same about the ECU. Seems a bit daft to have a limit though.
