Posted: Mon Aug 01, 2011 4:35 am |
Over the weekend I put a new phillips xenon kit on my car, had so muxh trouble with it and solved most of it except my engine management light is on cleared the codes yesterday and its come back on this morning nothing sounds wrong and the car still pulls as it should! I don't know if the xenon ballasts have f*cked the ecu up or not! Anyone had this problem or know what to do?
Posted: Mon Aug 01, 2011 4:36 am |
Like I told you the other day, make sure the ballasts are away from the ECU, Fusebox and ABS
Posted: Mon Aug 01, 2011 4:49 am |
I've moved them down near the foglights and all other warning lights went, and the engine management stayed on! Cleared the code yeterday and when I started up today the lights weren't turned on and bam engine managaement was on
