Online Now [333]:
Visitors: 332
Today: 54319
Total: 105948330
Forums › The Car › 206 Problems › Trouble Removing ARB
Lecktorious
PostPosted: Mon Aug 01, 2011 6:52 am Up
Trade Rating: +59
Hi guys,
Used Edward's guide for removing the ARB - the ARB slides out but seems to get jammed just before it comes completey out the crosstube. Anyone got any idea's how to remove this or what's causing it to jam?
Axle is off the car btw.
Cheers,
G
'98 Nile Blue 306 GTi 6
macj
PostPosted: Mon Aug 01, 2011 7:01 am Up
It would be the rubber seals.... thats all that can stop it coming out.... give it a good yank
Lecktorious
PostPosted: Mon Aug 01, 2011 7:02 am Up
Trade Rating: +59
Will give that a bash - tried before, will try sliding it back in and removing the seals as best possible.
PostPosted: Mon Aug 01, 2011 7:44 am Up
The guide didn't work at all for mine, snapped about 10 bolts and kept having to drill them out Laughing
In the end, i never changed it Laughing
Big_Rich180
PostPosted: Mon Aug 01, 2011 7:46 am Up
Lee wrote:
The guide didn't work at all for mine, snapped about 10 bolts and kept having to drill them out :lol:
Was that not your incompetence though Laughing
JK
PostPosted: Mon Aug 01, 2011 7:47 am Up
Probably Laughing
Was tempted to just get the grinder out and grind the end plates off Laughing
Big_Rich180
PostPosted: Mon Aug 01, 2011 7:50 am Up
Lee wrote:
Probably Laughing
That would have worked Laughing
PostPosted: Mon Aug 01, 2011 8:34 am Up
I've got two new end plates, so was really tempted Laughing
PostPosted: Mon Aug 01, 2011 11:31 am Up
My guide is perfect. It's idiot proof.
PostPosted: Mon Aug 01, 2011 11:32 am Up
Your guide is the exact same as Peugeot's. My car is just rusted to hell so its stuck
