Latest: S2cgm
Overall: 17178
Online Now [310]:
Visitors: 309
Today: 27495
Total: 137177297
Forums › The Car › 206 Problems › Radio beeping every few seconds after radio swap
Scusbucked
PostPosted: Wed Aug 03, 2011 4:49 am Up
Swapped my old Clarion CD radio for another one, after my old radio wouldn't get any radio frequencies in. Might work for a while then go static.
The new used was a matter of plug and play, but for some reason each time I switch it on it beeps every few seconds. I unplugged the battery, let it sit for a while and did a soft reboot, but the problem remains.
The only noticeable difference between the two is that my old radio had a fuse whereas the new one doesn't.
Does anyone have a solution for this?
- Scus
WTF - Welcome To Finland Wink
Ash
PostPosted: Wed Aug 03, 2011 4:53 am Up
Sounds like its a multiplexed radio and they needed to be coded to the car.
PostPosted: Wed Aug 03, 2011 4:54 am Up
Multiplexed radios are security VIN coded
You need to input the correct VIN number in to the radio, Peugeot planet is needed.
Scusbucked
PostPosted: Wed Aug 03, 2011 5:07 am Up
Hmm, if my car isn't multiplexed, will they get it to work?
Got a 2002 GTI...
- Scus
furryhobnob
PostPosted: Wed Aug 03, 2011 5:18 am Up
If yours is a 2002 gti it should be multiplexed anyway?
Scusbucked
PostPosted: Wed Aug 03, 2011 5:41 am Up
How can I determine if its multiplexed?
Throttle pedal is with a wire as is the clutch, I heard that you can determine it with this?
- Scus
copey
PostPosted: Wed Aug 03, 2011 5:50 am Up
radio stalks the easiest way, big fat and chunky its plexed
02 2.0 hdi d turbo
Scusbucked
PostPosted: Wed Aug 03, 2011 9:30 am Up
Swapped the stereos a few times to see if the display issued any clues.
With my old it says "Reg Off" and with the new one "Reg On". It seems this has something to do with it.
- Scus
PostPosted: Wed Aug 03, 2011 9:38 am Up
www.206info.co.uk/Foru...=1675.html
Scusbucked
PostPosted: Wed Aug 03, 2011 9:54 am Up
Ty Howey!
So my car is multiplexed Smile
- Scus
