Latest: Worthy967
Overall: 17143
Online Now [535]:
Visitors: 534
Today: 44917
Total: 115235403
Forums › The Car › 206 Problems › random messages on MFD on engine start
Junglingo
PostPosted: Mon Aug 01, 2011 6:18 am Up
My 180 has decieded to sometimes display random messages on the MFD on startup. Ice alert (when its 20+ degrees outside temp!!), airbag fault, ABS fault, braking fault... etc.. no unusual dashboard lights come on. switch off engine and a restart will be normal. car drives and works fine like normal so im sure this must be a fault with the BSI system or similar components? anyone else had this happen? thnx
GTi 180 - Scorpion Exhaust
PostPosted: Mon Aug 01, 2011 6:19 am Up
Got HIDs?
Junglingo
PostPosted: Mon Aug 01, 2011 6:20 am Up
nah, I got angel eyes with regular H1 bulbs. halos are hooked up to sidelights
Dan-
PostPosted: Mon Aug 01, 2011 7:24 am Up
My old done that once without ice alert, all warning cone up dash lights on, turned out a battery cll had died and needed a new battery
PostPosted: Mon Aug 01, 2011 7:48 am Up
Battery is dying/under charge then
Dan-
PostPosted: Mon Aug 01, 2011 7:54 am Up
If I have 1 just stick a multi meter onit, see how quickly the volts drop, mine was well dead, even after a 30min I drive put the meter on and it was losing a volt every 2 seconds
Junglingo
PostPosted: Thu Aug 04, 2011 5:26 am Up
will test battery out. thanks guys Smile
