Latest: lio94
Overall: 17181
Online Now [274]:
Visitors: 273
Today: 10118
Total: 141392827
Forums › The Car › 206 Problems › Overheating when idle
LWhite92
PostPosted: Tue Aug 02, 2011 6:31 am Up
Took my Sreg (1998) through a hand car wash the other day so was sat idle for around 20mins. Started off with temp gauge at 70'c and by the time i was finished 20mins later my gauge was waaay past 90 and my stop light had started to flash. Once i started driving again it quickly cooled back down to 70'c. Have also noticed that I never heard my fan come on and haven't done for months. Any ideas why it overheats so easily???
Has gone to the dark side!!!
Now driving a Black Magic Skoda Fabia vRS
NICKST
PostPosted: Tue Aug 02, 2011 6:45 am Up
While your stood still Thera no air flow to keep it cool. Would get the fan checked out tho.
PostPosted: Tue Aug 02, 2011 7:02 am Up
The relays on the fan or the connections will more than likely be shot on a car of this age
Take them out and clean and/or replace
MrrNoName
PostPosted: Tue Aug 02, 2011 11:59 am Up
the car will heat up when idle because there's no air flow cooling the rad and the pump is working slowly, but when it gets to about 90 the fan should come on to prevent it overheating. The fans not working Razz
sx206
PostPosted: Thu Aug 04, 2011 5:08 pm Up
why did you leave car idling for 20 minutes,just curious,but relays or temp sensor do sound suspect. Smile
206
Seb
PostPosted: Thu Aug 04, 2011 5:15 pm Up
Staff - Seb
Normally I turn my engine off in a car wash :/
LWhite92
PostPosted: Fri Aug 05, 2011 3:38 am Up
Think the switch is fried so gona try changing that over the weekend. I left it running cause it was a hand car wash so had 2 move forward a meter or so every couple of mins
sx206
PostPosted: Fri Aug 05, 2011 11:41 am Up
rather have dirty car than blown head gasket,are you serious about moving a meter for the cleaners every few mins. Surprised
206
PostPosted: Fri Aug 05, 2011 11:56 am Up
Definately check the connections to the relays and the wiring to the underside of the relays holders. Best to use a multimeter to check the power supply too.
If they aren't rotten I'd be very surprised. It should be a regular service item on all 206's now.
