pug206lx wrote:
Not read the manual on it but doesn't it turn the air conditioning back on when it detects a high level of heat in the cabin when you switch the ignition on?
That is partly correct.
If the cabin temp sensor picks up the temp inside the car is a lot different from what the climate control system temp is set to then the climate control will automatically turn back on & will try to heat up / cool down the cabin to get the temp back to what temp is selected.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
