Latest: tbafonso
Overall: 17130
Online Now [328]:
Visitors: 327
Today: 4773
Total: 104273168
Forums › The Car › 206 Problems › fan and temperature
fan and temperature
206racer
PostPosted: Sat Aug 06, 2011 4:08 am Up
I know there is a slow speed and fast speed.What temperatures should the slow speed come on,and what temp should the fast come on.I ask this because when i put air con on the fan doesnt spin but the aircon works,also the fan kicks in about 95 and then drops temp to 90(is this the slow speed)?Thanks
hello
MrrNoName
PostPosted: Sat Aug 06, 2011 4:11 am Up
my fan does come on when I put my aircon on regardless of temp,
at 93 degrees my fan comes on and goes off when the temp reaches just under 90, its a 1.4 petrol. sorry I cant help more Razz
PostPosted: Sat Aug 06, 2011 4:33 am Up
Fan should spin whenever the air conditioning is switched on.
