Online Now [292]:
Visitors: 291
Today: 67094
Total: 105109402
Forums › The Car › 206 Problems › Battery light
Battery light
Abzynthe
PostPosted: Thu Aug 04, 2011 7:33 am Up
East Area Rep - Abzynthe
This may be really simple, but I want to make sure before I go to a garage.
Basically my battery light comes on when the engine is on and stays on until I go over 2k revs then it goes off, but as soon as I brake or go under 2k revs the light comes back on again.
Is this just that the battery needs charging? It started just after a 2hr drive up to buxton so I would have thought the alternator would have charged it? :S
Big_Rich180
PostPosted: Thu Aug 04, 2011 7:38 am Up
Its a long shot but maybe the alternators weak and its not charging efficiantly below 2k rpm?
Abzynthe
PostPosted: Thu Aug 04, 2011 7:39 am Up
maybe, it doesnt struggle to start or anything and all the electrics work fine without the engine running.
Antknee
PostPosted: Thu Aug 04, 2011 7:40 am Up
thats what iwould have thought too, get a voltmeter on it Razz
Abzynthe
PostPosted: Thu Aug 04, 2011 7:42 am Up
ill have to pinch one off my dad, do you just put the probes on the +ve and -ve on the battery?
iainlovatt
PostPosted: Thu Aug 04, 2011 8:34 am Up
I hate to tell you this but that's what happened on mine, I took it to the garage and had a new one put on, cost me £100 quid or something! :0
(My Garage)
Abzynthe
PostPosted: Thu Aug 04, 2011 8:42 am Up
Sad one thing after another Laughing
im sure it will be ok for a little while until I can afford it.
PostPosted: Thu Aug 04, 2011 8:46 am Up
There not hard to change your self tbh, if it needs doing.
Make sure all you earth straps etc still all ok too,
MrrNoName
PostPosted: Thu Aug 04, 2011 8:59 am Up
weak alternator, doesnt put enough charge in untill its spinning faster then idle
PostPosted: Tue Aug 09, 2011 7:57 am Up
Is your aux-belt ok and not slipping?
Abzynthe
PostPosted: Tue Aug 09, 2011 8:56 am Up
Seems to have sorted it out at the moment. But I had the aux belt changed in June, so shouldnt be slipping.
mattievrs
PostPosted: Tue Aug 09, 2011 9:46 am Up
Aux belt tensioned properly?
NO LONGER ACTIVE ON THE FORUM
Abzynthe
PostPosted: Tue Aug 09, 2011 9:48 am Up
I hope so, I paid for a garage to fit it. If it comes back i'll take it back to the garage to have a look.
ian89
PostPosted: Tue Aug 09, 2011 1:52 pm Up
mines doing exactly the same only my light wont go off until after 3000 revs
