Posted: Thu Aug 04, 2011 7:33 am |
This may be really simple, but I want to make sure before I go to a garage.
Basically my battery light comes on when the engine is on and stays on until I go over 2k revs then it goes off, but as soon as I brake or go under 2k revs the light comes back on again.
Is this just that the battery needs charging? It started just after a 2hr drive up to buxton so I would have thought the alternator would have charged it? :S
| | ![](images/spacer.gif) |
Posted: Thu Aug 04, 2011 7:38 am |
Abzynthe wrote: |
Is this just that the battery needs charging? It started just after a 2hr drive up to buxton so I would have thought the alternator would have charged it? :S |
Its a long shot but maybe the alternators weak and its not charging efficiantly below 2k rpm?
Posted: Thu Aug 04, 2011 7:39 am |
maybe, it doesnt struggle to start or anything and all the electrics work fine without the engine running.
Posted: Thu Aug 04, 2011 7:40 am |
thats what iwould have thought too, get a voltmeter on it ![Razz Razz](images/smiles/icon_razz.gif)
Posted: Thu Aug 04, 2011 7:42 am |
ill have to pinch one off my dad, do you just put the probes on the +ve and -ve on the battery?
Posted: Thu Aug 04, 2011 8:34 am |
I hate to tell you this but that's what happened on mine, I took it to the garage and had a new one put on, cost me £100 quid or something! :0
Posted: Thu Aug 04, 2011 8:42 am |
one thing after another ![Laughing Laughing](images/smiles/icon_lol.gif)
im sure it will be ok for a little while until I can afford it.
Posted: Thu Aug 04, 2011 8:46 am |
There not hard to change your self tbh, if it needs doing.
Make sure all you earth straps etc still all ok too,
Posted: Thu Aug 04, 2011 8:59 am |
weak alternator, doesnt put enough charge in untill its spinning faster then idle
Any work you undertake as a result of my posts is done so at your own risk ![Smile Smile](images/smiles/icon_smile.gif) | |
Posted: Tue Aug 09, 2011 7:57 am |
Is your aux-belt ok and not slipping?
Posted: Tue Aug 09, 2011 8:56 am |
V9977 wrote: |
Is your aux-belt ok and not slipping? |
Seems to have sorted it out at the moment. But I had the aux belt changed in June, so shouldnt be slipping.
Posted: Tue Aug 09, 2011 9:46 am |
Aux belt tensioned properly?
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Tue Aug 09, 2011 9:48 am |
I hope so, I paid for a garage to fit it. If it comes back i'll take it back to the garage to have a look.
Posted: Tue Aug 09, 2011 1:52 pm |
mines doing exactly the same only my light wont go off until after 3000 revs
