Posted: Tue Aug 09, 2011 11:45 am |
Trade Rating: +46
im wanting my air bag ecu,s removed i know were one is but i beleve thair is two were is that one at, this should take the light of dash aswell yes....??????
for my track car...........
Posted: Tue Aug 09, 2011 11:48 am |
think is in front of the gear stick, under the ash tray
Posted: Tue Aug 09, 2011 11:56 am |
Trade Rating: +46
thort 180 had x2 ...dash light should go off aswell yes.......
Posted: Tue Aug 09, 2011 11:58 am |
No, you need to turn the airbags off in the BSI
Posted: Tue Aug 09, 2011 12:01 pm |
Trade Rating: +46
can you explain bsi please.........
Posted: Tue Aug 09, 2011 12:04 pm |
Basically like the motherboard of your PC. It controls the whole electrics.
Rip the sound card out of your PC and its going to throw up a whole load of errors, you would have to remove the drivers.
Same principle when removing the Airbag ECU from the car
Posted: Tue Aug 09, 2011 12:08 pm |
Trade Rating: +46
god you got me puzzled... so shall i leave it were it is then its not needed but lights on now since i replaced wheel seats...
Posted: Tue Aug 09, 2011 12:09 pm |
The BSI is your cars brain
Posted: Tue Aug 09, 2011 12:11 pm |
Trade Rating: +46
i,ll leave it then yer ...
Posted: Tue Aug 09, 2011 12:12 pm |
What are you wanting to do?
Remove all the SRS system?
Posted: Tue Aug 09, 2011 12:20 pm |
Trade Rating: +46
my car is a 206 gti 180 track car ive removed oem steering wheel and seats and fitted aftermarket ones, so i want to remove the srs system now as its not needed... also the light is now on so removing all this should also remove the light ...
Posted: Tue Aug 09, 2011 1:07 pm |
Oh the joys of modern cars
Posted: Tue Aug 09, 2011 1:10 pm |
Trade Rating: +46
yer love & hate
Posted: Tue Aug 09, 2011 2:14 pm |
Should have just measured the resistance to the airbag ecu when it was functional and then you could have just fitted a resistor
Or just remove the ECU, and de-solder the SMD for the airbag light
Posted: Wed Aug 10, 2011 9:47 am |
| shell-vt wrote: |
| thort 180 had x2 ...dash light should go off aswell yes....... |
Airbag ecu under front ashtray.
Satellite sensor on each sill for the side & curtain airbags.
Remove airbag ecu & sill sensors, turn ALL airbags & seatbelt pretensions off in BSI configuration, airbag warning lights will go / stay off.
