Posted: Tue Aug 16, 2011 2:05 pm |
started car earlier and the airbag light come on..nothing has been touched..any ideas ?
whats a good code reader for the 206 ?
cheers
(V) 99 GT/GTI/206
Posted: Tue Aug 16, 2011 2:09 pm |
I had one on mine a few weeks ago, was a loose connection under the seat for the driver seat airbag. CD-530D used this one on my car on sunday as it was throwing up a anti pollution light after I fiddled with the exhaust system.. and it worked fine cgi.ebay.co.uk/ws/eBay...2565wt_905
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Tue Aug 16, 2011 3:57 pm |
| JE_180 wrote: |
| I had one on mine a few weeks ago, was a loose connection under the seat for the driver seat airbag. CD-530D used this one on my car on sunday as it was throwing up a anti pollution light after I fiddled with the exhaust system.. and it worked fine cgi.ebay.co.uk/ws/eBay...2565wt_905 |
That code reader aint gonna scan an airbag fault code
Posted: Wed Aug 17, 2011 12:15 pm |
Posted: Wed Aug 17, 2011 1:08 pm |
forgot to mention...only noticed this from yesterday bout the same time as the airbag light has come on....when i start the car..i hear beep beep beep
dunno if this is connected or not
Posted: Wed Aug 17, 2011 2:18 pm |
Without getting it properly diagnosed, you will be clutching at straws. A likely candidate though is the "squib" behind the steering wheel. This "fires" the airbag and can just die. Our local Pug/Citroen specialist used a Snapon kit, but some older cars may need to be read with the proper Lexia software as they are non-standard diag systems before Sept 2001 for Petrol, and Sept 2004 for Diesel.
Lucky you don't have a multiplex .. the part was about three times the cost of the pre-mux when I changed ours a few years ago ... nearly £100! (that's the mux version)
Posted: Wed Aug 17, 2011 3:14 pm |
Posted: Fri Aug 19, 2011 11:48 am |
okies cheers again guys
Posted: Sun Aug 28, 2011 12:25 pm |
Alright bought my 206 y reg with the airbag light on (non flashing) but after replacing the passenger side wing which had a bump on it, seemed to have cured the problem with it for a quite awhile. noticed today it has come back on but its flashing now when i turn the car of n on it goes off but then come back on after awhile? does anybody no what could be causing this ??
Thankss
