Online Now [46]:
Visitors: 45
Today: 3122
Total: 104930827
Forums › The Car › 206 Problems › Dials faded need help
Foz369
PostPosted: Wed Aug 17, 2011 3:34 am Up
I took the cover off that covers the dials, and put it back on (with great difficulty) but now half of the rev counters lights are faded and the needle for the fuel gauge is also faded.
Is this fixable? What could be wrong?
sig removed due to size
Kersh
PostPosted: Wed Aug 17, 2011 7:29 am Up
sounds like youve knocked one of the connections on a bulb and its gone out
Member number: 36
Foz369
PostPosted: Wed Aug 17, 2011 6:11 pm Up
how would i solve this?
karimali831
PostPosted: Wed Aug 17, 2011 6:36 pm Up
mine also fades, I have to give it a bang and it is fine after, left side only.
206 GTI 180
chopsim1
PostPosted: Wed Aug 17, 2011 11:09 pm Up
Take the cover from around the cluster off, undo the torx screw and pull speedo unit out. The bulbs are in the back of cluster, small twist lock bulbs. Check they are all tight. If they are, then swap a few bulbs around and see which ones aren't working. They will probably have blackened glass if they are blown or you may be able to see the filaments are broken. (though they are quite small)
Thanks for reading
