Online Now [569]:
Visitors: 568
Today: 89047
Total: 105815657
Forums › The Car › 206 Problems › Broken Front Foglight
CUSMAN
PostPosted: Fri Aug 19, 2011 9:25 am Up
Hi folks! Smile
I have a 2000 206 2.0HDI with front fog lights and the drivers side foglight is broken.
....Okay, I broke it Embarassed
pushed too hard trying to get the damn spring clip that holds the bulb back into place when changing bulb and now the bulb holder is loose on one side inside the housing.
I've spoken to 2 main dealers...
one says the fog light can be changed by removing the spotlight through the hatch in the wheel arch
the other says you have to remove the whole bumper and its a £90 job! Shocked (excluding parts!)
Could anyone confirm which is correct please?
Any help will be very much appreciated!
Thanks,
because.
CUS
Abzynthe
PostPosted: Fri Aug 19, 2011 9:28 am Up
East Area Rep - Abzynthe
You can take the fog light off without removing the bumper. there's an access panel in the arch liner. Then to fix the fog, just separate the glass from the rest of the fog, push the chrome lense back into place and then seal the glass back on with silicone Smile
Depending on how long the silicone takes to dry its a 20-30 minute job Smile
PostPosted: Fri Aug 19, 2011 9:31 am Up
Not all 206's with factory fit front fog lamps have the access panel in the arch liner Wink
Abzynthe
PostPosted: Fri Aug 19, 2011 9:32 am Up
ah ok fair enough Smile
could always unscrew the arch liner from the bumper and do it from underneath?
CUSMAN
PostPosted: Fri Aug 19, 2011 9:35 am Up
You're my HERO!!!! Very Happy
Thankyou so much Abzynthe, very much appreciated (saved me a fortune!)
Mine does indeed have the access panel
Thankyou too MrBSI Very Happy
Take care Smile
CUS
CUSMAN
PostPosted: Fri Aug 19, 2011 9:53 am Up
Just a quick question before I get the big hammer out....
When I #cough# broke it the other day, I did try removing the unit through the hatch.
I unbolted the bolt at the bottom of the foglight mount and there are 2 prongs at the top that "slot" into the bumper.
I did try to pull the unit out, but it didn't want to come out of the slots at the top.
Do i just need to "persuade" it more? ...I was a bit careful, didnt want to break it anymore than I had Smile Do i just need to pull a bit harder?
Thanks again.
CUS
Abzynthe
PostPosted: Fri Aug 19, 2011 9:56 am Up
I think you have to tilt the lamp so the glass is facing the floor then it just pulls out Smile
CUSMAN
PostPosted: Fri Aug 19, 2011 10:06 am Up
Hmmm... I do recall it seemed to hit something on the left stopping it from being tilted very much.
Maybe it needs some twistyfication to the right Smile
I'll have another play & post how I get on.
Thanks again Very Happy
CUS
tiago90
PostPosted: Fri Aug 19, 2011 11:48 am Up
you can always get another fog light if you dont want to separate the glass from the rest of the fog ( its broken already so wont be a problem if you brake it a bit more) lol
CUSMAN
PostPosted: Fri Aug 19, 2011 11:54 am Up
Oh, I'll deffo give it a go repairing it as Abzynthe described Smile
So long as I can get the unit out of the access panel (really dont fancy pulling the bumper off Sad )
CUS
PostPosted: Sat Aug 20, 2011 5:47 am Up
Take the plastic archliner of Wink
CUSMAN
PostPosted: Wed Aug 24, 2011 7:39 am Up
Okies,
I've taken off the Arch Liner...the foglight wont pull out as the washer bottle stops it being tilted high enough to unclip....bugger! Sad
Soooo..anyone know how easy (Pleeease be easy!) the bottle is to remove please? Smile
Cheers
CUS
Mrs_Howey
PostPosted: Wed Aug 24, 2011 7:48 am Up
If you get really stuck it not hard to remove the front bumper
206info.co.uk/Forums/v...t=580.html
Heres my how to on removing it, it's a simple job if you get stuck and can't remove the light through the gap Smile
Would save you £90 as well Razz
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
