Latest: S2cgm
Overall: 17178
Online Now [104]:
Visitors: 103
Today: 6120
Total: 136651462
Forums › The Car › 206 Problems › PUG 206 HDI Engine Cover
Janetsman
PostPosted: Sat Jul 16, 2011 1:28 am Up
Can anybody give me any information on how to re fit the engine cover on
my 2,0 HDI. I believe the fastenings have broken and I need a new bolt set. Are there points on the engine block that these bolts fit into?
Any useful information would be appreciated.
muxloemax Turbo
kieron
PostPosted: Sat Jul 16, 2011 1:33 am Up
clips
You will need them buddy
Account suspended
Janetsman
PostPosted: Sat Jul 16, 2011 1:49 am Up
OK Thanks
muxloemax Turbo
DREWDEN
PostPosted: Sat Jul 16, 2011 1:57 am Up
Another anoying fault with the car. Known issue, last about ayear if lucky.
Put cover on, should line up with 4 holes.
put bolts and washers in mine 8mm i think, solved problem.
206 2ltr Hdi glx 53 plate
eddrj
PostPosted: Sat Jul 16, 2011 2:36 am Up
is easy to do , really annoying i had to keep doing it often on my old hdi , so much that i got fed up and just took it off.
Old car 2000/ 206 2.0 hdi.
DREWDEN
PostPosted: Sat Jul 16, 2011 11:01 am Up
Just read your question again, 4 bolts that your asking where they go in the engine bay need to be removed, as they often come away from the rubber.
Janetsman
PostPosted: Sun Jul 17, 2011 5:30 am Up
Yes you was correct they had snapped off and the bolts were still in the block. I think bolts and washers are a good alternative just need to find out what the thread size is and whether it is metric.
muxloemax Turbo
DREWDEN
PostPosted: Sun Jul 17, 2011 8:45 am Up
6mm by 50mm long, just take one of the bolts with you (wilkinsons) have a good selection of small packets.
On the inside of the cover put a washer, then a 25mm spacer, followed by washer,nut(finger tight) obviously a washer on the outside of the cover.
Works a treat, problem gone forever.
Just wondering, anybody know what function the cover does, the obvious i believe to keep heat to engine in, noise, protection.
Janetsman
PostPosted: Sun Aug 28, 2011 2:03 am Up
Hi Drewden not been on here for a while and just seen your message. This seems a really good alternative can you also buy the 25mm spacers from Wilkinsons?
muxloemax Turbo
Lecktorious
PostPosted: Sun Aug 28, 2011 7:28 am Up
Trade Rating: +59
Peugeot released a revised set of clips as the old version were prone to breaking.
Go and visit your local Dealership.
'98 Nile Blue 306 GTi 6
PostPosted: Sun Aug 28, 2011 8:33 am Up
Wasting your time, posted this info several times before, no f****r listens Rolling Eyes
Lecktorious
PostPosted: Sun Aug 28, 2011 8:35 am Up
Trade Rating: +59
Thought as such, would have thought the search function had been disabled Laughing
PostPosted: Sun Aug 28, 2011 8:38 am Up
It boils down to one of these:
Main dealer phobia
Rather buy cheap s**te from Ebay
Rather bodge it
