Latest: tbafonso
Overall: 17130
Online Now [190]:
Visitors: 189
Today: 10135
Total: 103801695
Forums › The Car › 206 Talk › How to help
How to help
r1ch
PostPosted: Fri Aug 19, 2011 2:37 pm Up
Hey, wondering if anyone can help on this matter.
I want to paint my front peugeot badge black to match the bumper. Do i need to sand it down and prime etc before hand or can i just paint over the top of it.
Also, which paint? Spray on or brush?
Thanks Very Happy
PostPosted: Fri Aug 19, 2011 2:39 pm Up
might be of some help .......... www.206info.co.uk/Foru...t=559.html
r1ch
PostPosted: Fri Aug 19, 2011 2:50 pm Up
thats great thanks pal.
LiamGTi180
PostPosted: Fri Aug 19, 2011 3:02 pm Up
choose a fine grit sand paper. sand it down. few layers of primer and leave the primer to dry... sand it down again and then apply colour. allow this to dry and then sand down if required. Then apply lacquer. Just remember to spray from a distance and apply in light coats slowly building them up. If it runs youve done it too thick. good luck
PostPosted: Fri Aug 19, 2011 3:10 pm Up
You dont need to sand it down between coats of primer when your using plastic primer.
craigy00craig
PostPosted: Fri Aug 19, 2011 4:20 pm Up
I did mine today and didnt use a primer or any sandpaper at all, just sprayed it straight away with gloss paint from halfords and came out perfect Smile
picture on page 3 www.206info.co.uk/Foru...tml#413638
Progress Threads:
PostPosted: Fri Aug 19, 2011 4:23 pm Up
It won't look perfect for long.
-xkellatronx-
PostPosted: Sat Aug 20, 2011 12:56 am Up
If you didnt sand it it'll peel off soon!!
Facebook: www.facebook.com/kelly.tompsett
kingdom200
PostPosted: Sat Aug 20, 2011 2:07 am Up
i never sanded mine and it was fine bar a few stone chips, but i do live in the middle of the countryside
PUG1OFF Cat Cams/ ECU project
craigy00craig
PostPosted: Sat Aug 20, 2011 6:37 am Up
i did a hell of a lot of coats so i dont think it should peel off, even if it does it wont be hard to spray again
Progress Threads:
Ali_H
PostPosted: Sat Aug 20, 2011 8:17 am Up
Or you could just do it properly in the first place.
kurtis wrote:
craigy00craig
PostPosted: Sat Aug 20, 2011 8:43 am Up
We will see
Progress Threads:
MthomasGTI
PostPosted: Sat Aug 20, 2011 2:00 pm Up
Omg... Omg!!!!!
Please prime it first, don't listen to Kermit here.
n00b from Notts Wink
-Dave-
PostPosted: Sat Aug 20, 2011 3:20 pm Up
Trade Rating: +36
What's the point in doing a half arsed job to save yourself a tiny bit of work. The time you spent doing loads of coats could have been spent doing the job properly. Bloody pure laziness. To the OP do the job right first time you won't have to worry about it in the future. There is a reason the sanding and priming process is there.
Ex 206 Owner.
