Latest: Kifi69
Overall: 17183
Online Now [532]:
Visitors: 531
Today: 158383
Total: 143998356
Forums › The Car › 206 Problems › Defect Master Cylinder
molldk
PostPosted: Fri Aug 12, 2011 9:55 am Up
Hi
I have a problem with my brakes.. I can brake to a point and after that point it just sink Shocked
I have checked for brake fluid and it's all there, but when pressing the brake pedal and listen to the reservoir your can hear a little squizing. Do any of you had a similar problem ? I'm suspecting the Master cylinder as I can't find any leak in the system, could it be other things ?
The car is a Peugeot 206 1.6i by the way
Thanks appreciate your help Smile
1999, 1.6, China Blue
Deckchair5
PostPosted: Sat Aug 13, 2011 1:00 am Up
If you're not losing any fluid and you have inspected the front and rear brakes for leaks and you have bled the brake system then yes it could well be the master cylinder
iainlovatt
PostPosted: Sat Aug 13, 2011 2:13 am Up
i have a mster cylinder if you need it, its off a 1.1/1.4.
(My Garage)
molldk
PostPosted: Sun Aug 21, 2011 6:56 am Up
Hi again
I finally figured it out.. Changed the master cylinder which didn't help, it shows out that right rear brake cylinder was out of position because of rust between the cylinder and the place it supposed to be at... :/ The area was cleaned and the cylinder was put in place again, now it works like a charm Very Happy Thought I would share it, if others have the same problem Smile
