Latest: lio94
Overall: 17181
Online Now [176]:
Visitors: 175
Today: 47755
Total: 141802325
Forums › The Car › 206 Problems › Brake Replavint tips
Linkpad
PostPosted: Mon Aug 22, 2011 3:20 am Up
I have attempted to fit new pads at the front and one of the 13mm inside bottom bolts had rounded off !! Tried everything to get it out the other side came loose though. Other thing is i have brake discs at the back and want to renew the pads there also Does the brake piston just push back like the front ones ?
I think its just a case of the right tools the 13mm Bolt isn't completely rounded its just on the inside at a hard to reach place !! Wall Bang
Boo
Abzynthe
PostPosted: Mon Aug 22, 2011 3:28 am Up
East Area Rep - Abzynthe
mole grips might work?
Linkpad
PostPosted: Mon Aug 22, 2011 4:03 am Up
I can't see how mole grips are going to take a 13mm Bolt off if a torque wrench can't. Im thinking power tools...
Boo
Abzynthe
PostPosted: Mon Aug 22, 2011 4:07 am Up
sorry I thought it was one of the caliper bolts. Yeah you might have to drill it out unless you can hammer in the torx bit to try and get a bit of the shape back.
Linkpad
PostPosted: Mon Aug 22, 2011 5:27 am Up
Yeah thats a good idea didn't think of the hammer and torx bit tah
Boo
PostPosted: Mon Aug 22, 2011 8:06 am Up
You shouldnt be removing bolts with a torque wrench, you will ruin it.
