Latest: Worthy967
Overall: 17143
Online Now [556]:
Visitors: 555
Today: 104007
Total: 114529102
Forums › The Car › 206 Problems › Problem With Gears Going from 5th or 4th !
Lornaandpug18
PostPosted: Mon Aug 22, 2011 2:31 pm Up
I've started to have problems with my gears for a couple of days now it did sometimes you to be a buggar getting into reverse,but lately it won't go into 5th from 4th at all its all stiff and just goes all tight since this has happened ocasionallt occasionally won't go into 4th from 3rd .. Does anyone know what could be causing this? Thanks
- x -
alyoung
PostPosted: Mon Aug 22, 2011 2:33 pm Up
Is there any noise when you drive it normally? Or does it slip out of any gear, at all?
2001 1.9Diesel (No ECU)
Lornaandpug18
PostPosted: Mon Aug 22, 2011 2:38 pm Up
No not really any noise it just don't want to get into gear, and no they normally work all fine its never slipped out of gear,
- x -
alyoung
PostPosted: Mon Aug 22, 2011 2:46 pm Up
Any "crunching" when switching between the gears, when it goes from 4th to 5th?
Lornaandpug18
PostPosted: Mon Aug 22, 2011 2:51 pm Up
Not really it does feel abit rough when changing then after its failed to get into 4th? I don't know why its doing it lol
- x -
az87aris
PostPosted: Mon Aug 22, 2011 4:05 pm Up
I'm no expert but It could be due to gear change linkage bushes being worn?
2000 Peugeot 206 1.4 LX owner
Lornaandpug18
PostPosted: Mon Aug 22, 2011 4:32 pm Up
Thanks I think I will take it too a garage and see what they say,
- x -
