Online Now [436]:
Visitors: 436
Today: 81588
Total: 142464347
Forums › The Car › 206 Problems › Backbox rattle
Backbox rattle
brimbo
PostPosted: Fri Aug 26, 2011 3:43 am Up
Noticed my backbox is making a rough rattling noise, I got told it sounds like the baffles inside my backbox, and its defiantly not my heat shield.
Far as I knew backbox's were hollow and the sound was judged on the dimensions Embarassed
Is it worth fixing or should I just replace it all together ?
W-reg 1.4 LX
PostPosted: Fri Aug 26, 2011 4:52 am Up
They aren't just hollow no but are you sure it's the backbox? Could be another part.
And loose exhaust clamps are also common suspects. Just take it off and see if it is the problem. If it is then isn't worth fixing no.
brimbo
PostPosted: Fri Aug 26, 2011 5:28 am Up
I'll be jacking it up next week sometime and looking properly then, wouldn't mind an aftermarket backbox anyways, give it a better purr !
W-reg 1.4 LX
fatboyslim
PostPosted: Fri Aug 26, 2011 6:05 am Up
Sounds about right,the baffles inside are made of mild steel and they rust which makes them come loose and then they rattle about
If you give the backbox a thump you can normally hear the baffles rattling
If they are loose then there's nothing you can do except replace it
Yes I own a CC and I'm neither gay or a hairdresser!!
brimbo
PostPosted: Fri Aug 26, 2011 6:14 am Up
Yeah, just give it a welly and sounded like a lot of rattling inside. Is it a case of hacksawing the backbox of and welding on a new one? or is there a method to it
W-reg 1.4 LX
fatboyslim
PostPosted: Fri Aug 26, 2011 7:00 am Up
No shouldn't be any sawing needed
It should be joined to the centre section by a clamp
