Latest: tbafonso
Overall: 17130
Online Now [305]:
Visitors: 304
Today: 73051
Total: 104262667
Forums › The Car › 206 Problems › Pairing Key Fob To Car
PaddyC
PostPosted: Sat Aug 27, 2011 2:47 pm Up
I got a new remote key direct from Peugeot and it only actually locks and unlocks the car remotely after it has been in the ignition. If I come back to the car an hour later the unlock button does nothing. Surely that can't be right, it's a new key with presumably a new battery in it and it took them 45 minutes to code the key to the car. So, how I do manually re-pair it myself to see if that works. If not it's back to Peugeot to complain.
Peugeot 206 1.4HDI Style
PostPosted: Sat Aug 27, 2011 3:00 pm Up
think you need to pair the all the key remote and chip all in one go.
pug206lx
PostPosted: Sat Aug 27, 2011 5:16 pm Up
Only works if the key is already programmed to the car, from what youre saying it is.
Quote::
206 PLIP PROGRAMMING SYNCHRONISATION—BSI
1. Insert the Ignition Key.
2. Press the small Black button.
3. Switch the Ignition ON
4. Keep the lock button pressed for 10 seconds.
5. Release lock button , switch ignition OFF and remove key.
6. Close all doors and press the lock button 2 times.
PaddyC
PostPosted: Sun Aug 28, 2011 4:17 am Up
Ta. Will give this a try shortly and see how I get on. Smile
PostPosted: Sun Aug 28, 2011 5:09 am Up
What He Said
A new / replacement fob needs to be coded to the car with Peugeot Planet along with ALL the other remote & transponder keys at the same time.
PaddyC
PostPosted: Mon Aug 29, 2011 4:42 am Up
Still wasn't working after trying to air it twice so I took it down to Peugeot and they have it booked in for Thursday for an inspection as there is no fault with the key but possibly with the cars BSI forgetting the key every time it powers down. Thanks for the help. Smile
