Online Now [318]:
Visitors: 317
Today: 63474
Total: 105957466
Forums › The Car › 206 Problems › Water noise from glove box area
Go to page Previous  1, 2
jcowan
PostPosted: Wed Nov 16, 2011 4:44 am Up
greenpug2222 wrote:
I have this too,
It seems to only make the water noise upon acceleration. Even in neutral for a good while, whilst it warms up.......... then after it seems to get less and less.
Yup i get that to, Press the throttle and there's like a rush of water coming from around the glovebox area, dont have a clue what it is. I have looked and it doesnt seem to be a Cause of any problems but as i said i really dont know, I do hope it isnt the head gasket. My last car's gasket went absolute nightmare, Rover 400 1.4 though, seems to be expected Laughing
2003 1.4 LX Silver.
greenpug2222
PostPosted: Fri Nov 18, 2011 3:17 am Up
if this is the head gasket then why does it not do it all the time???? and not just when im driving a cold car.
why wont you work??????????????????? ARGH F**k it!!!!!
Reflekt.
PostPosted: Fri Nov 18, 2011 5:29 am Up
It's just ure coolant system running through the heater matrix. You may have a bit of air lock in the system causing the trickling noise that's all!
2.0 HDi Moonstone Blue Progress Thread
2.0 HDI... Carbon front badge, Black rear lights, PH2 bootstrip, Honeycombe grill
Reflekt.
PostPosted: Fri Nov 18, 2011 5:32 am Up
Ok I posted without reading the first post, so ignore the above comment lol!
rick-gti
PostPosted: Fri Nov 18, 2011 5:36 am Up
What He Said
had the same noise with both 306 gti6's i owned shouldnt be anything to worry about.
clio 197sport owner
Kersh
PostPosted: Fri Nov 18, 2011 6:42 am Up
because metal expands and creates a tighter seal on the gasket? thus reducing/eliminating any air leak
Member number: 36
greenpug2222
PostPosted: Tue Nov 22, 2011 3:15 pm Up
ok ive looked into this a bit more and it only seems to do it in 1st-3rd gear. Im not saying its related but this is what ive witnessed.
my car does not over head and the temp needle sits between 80-90 ish all the time....
Does everyone still think its the head gasket????
rick-gti
PostPosted: Wed Nov 23, 2011 2:39 am Up
Take it to a garage and ask them to check for exhaust gasses in the coolant. thay will tell you if the head gasket has gone/is going.
clio 197sport owner
Daza
PostPosted: Fri Nov 25, 2011 11:51 am Up
this started happening on my car and i checked the coolent level and it was really low (took nearly 2 ltrs of water to get back to normal level) and now its fine, always check the easy/ less expensive stuff first lol
PostPosted: Fri Nov 25, 2011 11:55 am Up
water / heater pipes that come in and out cabin are down glovebox side,
check its bled and not low on water. or even leaking.
greenpug2222
PostPosted: Wed Dec 21, 2011 7:02 pm Up
My car is still doing this,
Ive found that somehow water is being spray/leaked out of the expansion tank but i can not find out where. The lid is on tight,there are no cracks or holes in it and i still get the noise.............
PostPosted: Thu Dec 22, 2011 4:34 am Up
Change the pressure cap then, if the spring inside is weak it will allow the coolant to escape out.
There only £3.67 new from any Peugeot / Citroen main dealer.
Page 2 of 2
