Posted: Tue Aug 23, 2011 10:19 am |
What's the difference?
I'm sure I've read somewhere that hatch clusters can be modified to fit, so I assume there is a small difference?
I'd like to fit a pair of Phase 2s to the CC.
| | ![](images/spacer.gif) |
Posted: Tue Aug 23, 2011 10:22 am |
Think its the rain gaurd, the little black bit inside :/ not to sure dont hold me to it! But can be modded mate!
Posted: Tue Aug 23, 2011 10:32 am |
it is indeed, if you buy some you can trim the plastic flappy bit to size using your current CC ones as a template
Posted: Tue Aug 23, 2011 1:37 pm |
Loads of proper CC lights on Ebay
| Yes I own a CC and I'm neither gay or a hairdresser!! | |
Posted: Tue Aug 23, 2011 1:45 pm |
Surely you can buy some phase two CC lights from somewhere?
Posted: Tue Aug 23, 2011 3:17 pm |
AshH wrote: |
Think its the rain gaurd, the little black bit inside :/ not to sure dont hold me to it! But can be modded mate! |
100% correct, the black plastic rain guard clipped on to the cluster, easily swoppable if you want.
Posted: Sat Sep 03, 2011 11:10 am |
Edward wrote: |
Surely you can buy some phase two CC lights from somewhere? |
Add CC to the search and the price goes up!!
You can get LED hatch rear brake lights for around £20, but go for same for CC and you're looking at £35!! Same with rear light clusters.
Posted: Sat Sep 03, 2011 11:58 am |
i got mine for 15 inc postage ill pm you a 206cc breakers that is very cheap
Posted: Sat Sep 03, 2011 12:04 pm |
pm'd
Posted: Mon Sep 05, 2011 3:05 am |
OK, checked the rear lights and the lamp is the same. The difference is the black splash guard which is much larger on the hatch version. But this seems to just clip on .. so next up is a bit of work with some small screwdrivers, etc., to see if I can get these off in one piece. Then do same for existing CC lamps, swap and put back!
Should be interesting ...
Posted: Mon Sep 05, 2011 3:17 am |
gazza82 wrote: |
OK, checked the rear lights and the lamp is the same. The difference is the black splash guard which is much larger on the hatch version. But this seems to just clip on .. |
this is exactly what was said above
Posted: Mon Sep 05, 2011 6:37 am |
I missed Mr BSI's post ... ![Sad Sad](images/smiles/icon_sad.gif)
But I'll also question the "easy" bit .. mine attempts at the weekend didn't get one off. The three clips aren't that easy to move (I managed one!) and it looks like it may also be "plastic welded" at the top and bottom corners. There's a little round fitting that definitely doesn't want to flip off that easily.
As I'm working on the Phase 2's at the moment, I obviously am taking my time as I don't want to break them!
