Online Now [74]:
Visitors: 73
Today: 62878
Total: 105326149
Forums › The Car › 206 Talk › How to disconnect this ?...
davieboy86
PostPosted: Sat Sep 03, 2011 7:14 am Up
I'm just changing my solenoids over but I can't see how to remove this White rod that connects to the outer door lock. In middle of the pic
In the scrapyard when removing the solenoid I just snapped it but obviously can't so that on my car lol
Stuck, sitting in the gravel outside my house stuck lol
PostPosted: Sat Sep 03, 2011 7:18 am Up
Pull the metal 'U' shaped clip off and it pulls out. Slide it to the left in the pic.
smiddies
PostPosted: Sat Sep 03, 2011 7:29 am Up
You sure you know what your doing....
this post springs to mind...
MrBSI wrote:
Do either of you 2 actually know what your talking about? Rolling Eyes
Door lock barrels on a 206 & most other PSA Peugeot / Citroen stuff, p**s easy job, less then 90 seconds a side, no need to remove the door card, Peugeot designed in an easy way of removing the lock barrel securing clip.
Remove rubber bung.
Insert your threaded tool & screw it in to the clip.
Push the tool in to the door to release the clip.
Lift the barrel out & unclip it.
Refitting is reversal of removal.
Ignition barrel - about 5 minutes:
Remove the plastic trim around the steering lock.
Unplug the barrel from the wiring loom.
Check for a small securing grub screw in end of barrel ( not all barrels have this! )
Insert key & turn to the LOCK SERVICE position.
Push the securing clip down & then pull the barrel out the steering lock, if the transponder aerial gets in the way unplug / unclip it.
I also find that the V shaped holder/clip is a bit of a pain, I used a flat head and a hammer! Smile
PostPosted: Sat Sep 03, 2011 7:57 am Up
Yes, done it plenty of times Wink
PostPosted: Sat Sep 03, 2011 10:14 am Up
Do as CD-530d said,take the lock out,and it will go out easily,it's a lock,that is why you are stuck
