Latest: Stu-mill
Overall: 17131
Online Now [547]:
Visitors: 546
Today: 49420
Total: 104858261
Forums › The Car › 206 Talk › change rear engine mount
russellg86
PostPosted: Tue Sep 06, 2011 1:14 pm Up
just had a look and my engine mount is gone in my HDI and there is a drive shaft going throw it do i need to take the full drive shaft off or is there a easy way to do this??
NO smoke NO poke!
PostPosted: Tue Sep 06, 2011 1:19 pm Up
Shaft needs to come out. It's not that big a job once you have the hub nut undone.
PostPosted: Tue Sep 06, 2011 1:22 pm Up
and you will have to press the bush out from the mount
russellg86
PostPosted: Tue Sep 06, 2011 1:26 pm Up
bush just crumbled out lol its ready to come off but just need the weather on my side and was wondering if i was gona make more work for my self cheers
NO smoke NO poke!
