Forums › The Car › 206 Talk › change rear engine mount |
Posted: Tue Sep 06, 2011 1:14 pm |
just had a look and my engine mount is gone in my HDI and there is a drive shaft going throw it do i need to take the full drive shaft off or is there a easy way to do this??
Posted: Tue Sep 06, 2011 1:19 pm |
Shaft needs to come out. It's not that big a job once you have the hub nut undone.
Posted: Tue Sep 06, 2011 1:22 pm |
and you will have to press the bush out from the mount
Posted: Tue Sep 06, 2011 1:26 pm |
bush just crumbled out lol its ready to come off but just need the weather on my side and was wondering if i was gona make more work for my self cheers
