Posted: Thu Sep 08, 2011 3:34 pm |
My 206 HDI frequently has a steering problem. As I turn the wheel it feels like something grips it so it becomes really hard to turn. Often it needs to be forced round to unstick the wheel. This occurs at all speeds it seems and at any angle/rotation.
The dealer's taken a look twice and hasn't a clue.
I can't believe I'm the only 206 owner with this problem.
Can anyone help?
Thanks.
| | ![](images/spacer.gif) |
Posted: Thu Sep 08, 2011 4:13 pm |
Trade Rating: +59
Need to know what varient of HDi it is (DW, DV4, DV6...)
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Thu Sep 08, 2011 4:59 pm |
ive got a similar problem, my car seems to become slightly harder to turn once and a while, but try getting the timing belt changed, i know it sounds stupid but before my old one snapped it kept slipping off and n making t harder to steer
| Breaking 2.0 hdi with ps and gti bits | |
Posted: Fri Sep 09, 2011 4:30 am |
deebee wrote: |
ive got a similar problem, my car seems to become slightly harder to turn once and a while, but try getting the timing belt changed, i know it sounds stupid but before my old one snapped it kept slipping off and n making t harder to steer |
The timing belt should never ever "slip off" lol are you certain you dont mean aux belt.
Any work you undertake as a result of my posts is done so at your own risk ![Smile Smile](images/smiles/icon_smile.gif) | |
Posted: Fri Sep 09, 2011 4:34 am |
MrrNoName wrote: |
deebee wrote: |
The timing belt should never ever "slip off" lol are you certain you dont mean aux belt. |
that would then mean loss of battery power, so could of been the power steering going
Posted: Sun Sep 11, 2011 4:01 am |
G. wrote: |
Need to know what varient of HDi it is (DW, DV4, DV6...) |
It's the 206 GLX HDI Engine No starts DYGX... Does that help?
Thanks.
Posted: Sun Sep 11, 2011 4:05 am |
The problem has existed for several years now but has become more frequent recently. The car has been worked on over the years by both a Peugeot dealer and a reputable local garage. So I don't think what I'm experiencing isn't due to some sudden, one-off event like a timing belt problem.
More thoughts anyone? Thanks.
Posted: Sun Sep 11, 2011 5:17 am |
Tricky but I think I'd check the track rod ends for stiffness, sometimes, holding the rod end whilst someone carefully moves the steering for you then you can feel it binding. Look for damaged boot covers on them that would allow water in
Make sure it's nothing obvious like car mat getting in the way
Other than that then i think I'd check for stiffness in the steering rack itself, maybe raise the front and turn the steering
Posted: Sun Sep 11, 2011 7:57 am |
Thanks Deckchair5
