Online Now [91]:
Visitors: 90
Today: 1359
Total: 138932001
Forums › The Car › 206 Problems › oil pressure seal
oil pressure seal
dumdum0910
PostPosted: Thu Sep 15, 2011 2:09 am Up
i have noticed oil coming from the bottom of the oil filter housing. are you able to buy the seals for the switch?
PostPosted: Thu Sep 15, 2011 4:13 am Up
Yes, go to any Peugeot / Citroen main dealer, they will most likely also be in stock.
Are you 100% sure its not the actual oil pressure switch leaking? Wink
dumdum0910
PostPosted: Thu Sep 15, 2011 4:41 am Up
ive got the seal i will replace that and if it doesnt stop i will replace the switch
