Latest: jackrox1992
Overall: 17186
Online Now [372]:
Visitors: 371
Today: 137770
Total: 148507087
Forums › The Car › Solved 206 Problems › Sudden loss of power while hot solved.
Forum Index › Solved 206 Problems
zoranm1976
PostPosted: Sun Oct 02, 2011 9:48 am Up
Hello.
I am writing you from Mostar, Bosnia and Herzegovina.
I had lots of problems with my 2002 206 1.4 XS LPG converted going uphills while hot. Specially when AC was on. Car was losing power almost stalling and my fuel economy was poor also.
I tried with changing spark plugs from NGK platinum to Bosch Super 4-s, car was running better but it was still not it. Fuel economy remained the same and car was dying going uphills on low speeds under 60 Km/h. Engine Temp in that cases was well above 90 Celsius even more than 95.
Then I decided to change Oil after 20.000 Km 10.000 made on LPG. I decided to use Total Quartz 5w40 full synthetic a bit more expensive than 10w40 semi synthetic oil. I changed oil and air filter also. And voila my car after few kilometers was running much better and fuel economy improved by 1.5 liter per 100 km mostly urban driving.
Mid 2002 206 1.4i XS LPG converted
brad-morris
PostPosted: Sun Oct 02, 2011 10:17 am Up
Happy Days Thumb Up
greg.mitchell350
PostPosted: Sun Oct 02, 2011 12:48 pm Up
the old oil must of been in awful condition!
206 enthusiast
PostPosted: Sun Oct 02, 2011 2:45 pm Up
13000 miles a service you probably want full syn with extended drain interval oil.
zoranm1976
PostPosted: Mon Oct 03, 2011 5:05 am Up
As I remember even with 10W40 i should have service interval on 30.000 km. Then there is probably error in their manuals. Newer the less from now on I change oil an filters on 10.000 km.
