![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Talk › What is this for?? |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Fri Sep 16, 2011 3:01 pm |
| 2002 Peugeot 206 GTi 2.0 16v 137Bhp | |
![](images/spacer.gif) |
Posted: Fri Sep 16, 2011 3:12 pm |
any numbers on the wires?
Posted: Fri Sep 16, 2011 8:45 pm |
kinda looks like the reverse light switch but i may be way wrong, can you get better pictures up? failing that i'm sure someone else will know
Posted: Sat Sep 17, 2011 12:40 am |
This is where it's supposed to sit...it sits on top of the oil filter housing but it's not the oil pressure sensor. It just seems to be a connector to bridge the loom.
![](http://i38.photobucket.com/albums/e105/s1pso/SDC17247.jpg~original)
Posted: Sat Sep 17, 2011 2:21 am |
Is there a wire in the black trunking in the top right of picture??
Posted: Sat Sep 17, 2011 3:59 am |
macj wrote: |
Is there a wire in the black trunking in the top right of picture?? |
Black trunking? you mean the protective thingy? That's the connector I'm talking about, the other part of the cut off blue wire is inside that, I revised the picture for it to make a bit more sense - will see if I can get a better pic today.
Posted: Sat Sep 17, 2011 4:03 am |
Is it for the air con pump? I'll have a look at mine shortly.
Posted: Sat Sep 17, 2011 4:17 am |
looks like the oil pressure switch to me..... Check yours Ed. The picture is taken from below and makes it a little confusing. I think its the oil filter just above it.
Posted: Sat Sep 17, 2011 4:30 am |
The the oil filter is in the top right corner, you can just see the rusty ring and the round shape of it ![Razz Razz](images/smiles/icon_razz.gif)
Posted: Sat Sep 17, 2011 4:32 am |
macj wrote: |
looks like the oil pressure switch to me |
The broken wire on the loom, with the engine running touch it to earth & see if the oil pressure warning light flashes up on the instrument cluster ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Sat Sep 17, 2011 10:55 am |
I was looking at the connector in the centre of thepicture which is definately for the air con pump. Didn't see the little red circles.
Posted: Sat Sep 17, 2011 11:35 am |
Edward wrote: |
I was looking at the connector in the centre of thepicture which is definately for the air con pump. Didn't see the little red circles. |
I dont remember seeing the little red circles earlier either ![Confused Confused](images/smiles/icon_confused.gif)
Posted: Sat Sep 17, 2011 11:38 am |
Edward wrote: |
I edited it after you mistaking, that it was that one So you're not seeing ghosts ![Laughing Laughing](images/smiles/icon_lol.gif)
But I did also ask about that connector, I guessed it was air-con anyhow ![Razz Razz](images/smiles/icon_razz.gif)
Posted: Sat Sep 17, 2011 11:42 am |
did you try earthing it??
Posted: Sat Sep 17, 2011 12:30 pm |
Here's mine...
![](http://i38.photobucket.com/albums/e105/s1pso/SDC18943.jpg~original)
| ![](themes/base/images/forums/otr.gif) |
