Latest: tbafonso
Overall: 17130
Online Now [59]:
Visitors: 59
Today: 9905
Total: 104480035
Forums › The Car › 206 Problems › Rattle & other weird noises after new clutch+flywheel
tubbe2
PostPosted: Sat Sep 17, 2011 2:47 pm Up
After I got my clutch & flywheel (new lightened) replaced, my car is now making a rattle/clicking noise while it's in neutral and the clutch engaged. The rattle/click noise stops if I fully depress the clutch pedal (you can hear it in the video). Any clue why it's doing like this suddenly?
(watch in 720p)
My iPod fell down because of vibration, I was like "ooooh s**t" Laughing
Another thing, also after having the two replaced, it's also making a slightly different rattle noise now around 2000-2800 rpm, while driving Confused
This is really making me crazy! The mechanic who did the replacing is a friends stepbrother, so making any complaint to him probably won't do s**t Evil or Very Mad
(recorded with my phone, hence the bad picture)
The quality is kinda low, and the mic in my phone is just as bad, so you can only slightly hear the noise - it's only there the first couple of minutes. The rest is me driving Razz Sidenote: it looked like the car @8:30 wasn't going to stop and drive straight out in front of me, got a bit scared Shocked
2002 Peugeot 206 GTi 2.0 16v 137Bhp
macj
PostPosted: Sat Sep 17, 2011 3:00 pm Up
I would get it back to them to check.... you will get a lumpier idle with a lightened flywheel if its very light... but there is something not quite right
tubbe2
PostPosted: Sat Sep 17, 2011 3:24 pm Up
Yeah, I already knew that with the idling, but the rattle is not related to that. It follows up with the rpm's, with the clutch engaged Confused
The flywheel is supposed to be around 3kg's lighter anyhow, don't know how 'light' that is.
I'm going to write to him, problem is that it was illicit work, so don't have anything on it, he could just say he doesn't care.
I have a feeling that he just wanted to finish it as fast as possible, and just smacked it back in... (His Opel Corsa Super 1600 had broken down, and he needed it for some competition this weekend)
I had to reassemble my K&N air intake kit myself, as he just have shoved it back in after removing it, and it was hanging loose, plus the intake pipe was just put/stored inside the wheel arch lining Confused
macj
PostPosted: Sun Sep 18, 2011 2:12 am Up
I think you need to get the box back out.... I wouldnt drive it till you have checked inside. The clutch pressure plate could be loose, the release bearing could be hanging off its arm or worse case..... The flywheel is loose.
leigh_boy
PostPosted: Sun Sep 18, 2011 2:13 am Up
when you fitted the fly wheel did you tighten the bolts in a sequence? and lock tight them?
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
macj
PostPosted: Sun Sep 18, 2011 2:18 am Up
He didnt fit it himself
PostPosted: Sun Sep 18, 2011 3:15 am Up
3kg sounds a lot to be removing from the flywheel.
macj
PostPosted: Sun Sep 18, 2011 3:25 am Up
It is when the standard one is 6.7kg
tubbe2
PostPosted: Sun Sep 18, 2011 4:06 am Up
The clutch & flywheel was 14kg together - 3kgs lighter might just have been a sales trick on the ebay auction...
I feel unlucky Sad
PostPosted: Sun Sep 18, 2011 4:54 am Up
Yee ha!
You can see the spur marks from here Rolling On The Floor Laughing
PostPosted: Sun Sep 18, 2011 7:03 am Up
you buy clutch and flywheel on ebay Confused
