Forums › The Car › 206 Problems › Under the bonnet! |
Posted: Mon Sep 19, 2011 11:33 am |
Hi,
Firstly, in the last couple of weeks ive noticed a loud buzzing noise from under the bonnet, not been able to find the source until today!
The noise only happens when the engine is cold and at about 3500-4000 rpm.
Appears to be coming from the cam belt cover not been clipped together properly, when i hold the revs at about 3500rpm and hold the cover together with my hand the noise stops!
On the pics it looks like there should be a clip holding the 2 sides together, anyone got a idea on what clip it would be?
Also, cleaned up my air filter earlier to find underneath the air box there was a wire thats been snapped off, anyone know what it is and what its for?
Cheers.
Posted: Mon Sep 19, 2011 2:22 pm |
I've never seen anything attached to the cambelt cover on any Peugeot (ot just 206) so don't worry about it.
Are the screws holding the cover in place all tight?
Posted: Mon Sep 19, 2011 3:15 pm |
Ok mate, just looks like there should be something holding it together thats all! The screws seem pretty tight but ill check again tomorrow to make sure if thats all it could be!
Posted: Mon Sep 19, 2011 4:31 pm |
I'll take a look at mine tomorrow mate, no offence but I cba at this time of night
Posted: Tue Sep 20, 2011 3:21 am |
Yeah no worries mate, appreciate it!!
Posted: Tue Sep 20, 2011 4:25 am |
ye no clips just screws
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
