Online Now [117]:
Visitors: 116
Today: 82883
Total: 105976811
Forums › The Car › 206 Problems › Oh dear, gearbox help :(
Rob2859
PostPosted: Wed Sep 21, 2011 1:08 pm Up
My driveshaft was slipping on Monday and yesterday it went. I recovered my car and had a look today. I already bought another shaft expecting it to be that. However its slipping inside the gearbox; Can we just confirm that it is f****d?
Also I was told the gear ratio's in 1.4's are shorter for some reason, can someone confirm this too?
kieron
PostPosted: Wed Sep 21, 2011 1:10 pm Up
Sound like the diff has shat itself
Account suspended
is the differential working?
if you want to know the gear ratio check on servicebox
Rob2859
PostPosted: Wed Sep 21, 2011 2:45 pm Up
The diff seemed to be working. I am looking on servicebox but struggling to find it =/
imjeeves
PostPosted: Wed Sep 21, 2011 3:41 pm Up
This a common problem with the MA box as the crown wheel is simply an interference fit. When the cars have done a fair milage or been rallied about the crown wheen breaks off its normal location.
Two options
1. Bin the box and get another
2. Get a machine shop to open the box and pin the crown wheel in place (i have had this done and it work 100% now)
PostPosted: Wed Sep 21, 2011 3:43 pm Up
Two options
so do you mean the crown wheel fall off from the differential?
can't believe that could happen Confused hard to believe it can break through 8 bolts
Rob2859
PostPosted: Wed Sep 21, 2011 3:47 pm Up
Thanks for the info. If I stick my finger in the box I can feel something in the way but there is still a gap to get my finger down the box. I am better off with another box as its on nearly 110k. I can get a 58 plate box for £150 but I am just wondering about the 1.4 boxes. If its a bit shorter then that would be better. Can't find the info on service box though.
imjeeves
PostPosted: Wed Sep 21, 2011 3:49 pm Up
Its not bolted in an MA box its pressed on. Hense why it breaks off!
PostPosted: Wed Sep 21, 2011 3:50 pm Up
is that a 206 box?
you have to make sure it run rod linkage and cable clutch.
Matt
Trade Rating: +32
I've got a box you can have for £100.
Done around 40k.
(I'm only in Manchester)
Rob2859
PostPosted: Wed Sep 21, 2011 4:11 pm Up
What engine? I will have to see as I will still need to pay someone £15 petrol; if I find anyone that will get it for me.
PostPosted: Wed Sep 21, 2011 4:13 pm Up
Embarassed didn't know that Embarassed
Matt
PostPosted: Wed Sep 21, 2011 4:30 pm Up
Trade Rating: +32
Think it's a 1.1 but not 100% without looking.
Rob2859
PostPosted: Wed Sep 21, 2011 4:49 pm Up
well check for me when you get a chance. Still looking into a 1.4 box but can't find any details
Rob2859
PostPosted: Wed Sep 21, 2011 5:16 pm Up
I did find this
www.saxperience.com/fo...p?t=125615
I could get a 1.4XSI or ether of the rallye gearboxes if they fit.
